Drag Wheels opinions needed
2) Our wheels are built to fit your car using OEM brakes/calipers/rotors. Moot point for you right now as you've modified the car to make yours fit.
3) Our Bogart wheels quality is much higher. We are not using stamped materials with a loose cast aluminum spacer with our wheels. Our centers are machined 6061 billet; the shells are spun forged and hardened. Wheels MAKE the car's appearance. It is one of the most recognizable modifications you or anyone else will see anytime you drive the car.
4) No drag wheel is designed for street use...if you feel comfortable using a drag wheel intended for drag use on the street as you’re doing right now, then you may feel no different with our wheels.
*for reference, for every 1 lb of rotational weight, easily add 4lbs of static weight as a converstion factor. Depending on the manufacture, some suggest 6-8lbs...
