Lets see your Staggered rims!!!
Old Apr 2, 2008 | 10:18 PM
BlkBird2000's Avatar
Default Lets see your Staggered rims!!!
Thinking about replacing my 17x9.5 z06s for some 18x10.5s Can't decide on how it looks. Opinions? Lets see your staggered rims!!!
Old Apr 3, 2008 | 06:15 AM
Come on I know you guys are out there!
Old Apr 3, 2008 | 08:11 AM
Xsta Z 28's Avatar
I pesonally do not like the look. F-Cars need the OD of the tire to be close to the same, or the ABS computer will get upset. . . . So to do that the side wall of the front tire is taller than the rear tire . . .
So my honest opinion is 18x9.5 front and 18x10.5 rear!
Old Apr 3, 2008 | 12:45 PM
goofyfootsurf's Avatar
Old Apr 3, 2008 | 12:52 PM
Jays00ss's Avatar
Here is mine. I have a 9" with a detroit locker and TCS, no issues at all. 17x9.5 front and 18x10.5 rear
Old Apr 3, 2008 | 08:52 PM
SIC LSX's Avatar
here ya go 17x9 and 275/40 front and 18x10.5 and 295/35's rear
I was going to get 18x9's for the front untill i saw this pic. now i just need to lower it.
The cheepest 295/35 you can get is a toyo
http://www.tiredeals4less.com/TOYO_P..._103_P1897.cfm
The The Firehawk Wide Oval is another good deal on tirerack.com
http://www.tirerack.com/tires/tires....e1=yes&place=0
Old Apr 3, 2008 | 08:57 PM
SIC LSX's Avatar
as long as your tire height is close your good. Wheel size has nothing to do with it it overall height. I had a friend that had the same size wheel all the way around had is front tires shorter then rear and when he would go around a corner with traction control on it would said low trac. But that didnt really matter he just turns it off every time he gets in the car anyways. Yes 295's are a little taller then 275s but i have put a ton of miles and had to slam on brakes a few time and same a stock no change
Old Apr 3, 2008 | 08:58 PM
OSUBraden's Avatar
Looks horrible most of the time. Fill your wheel wells out with 18s and get a nice kit to make it all sit right (fender gap wise).
Old Apr 3, 2008 | 09:18 PM
bene's Avatar
Trunion King
Go 18s all around, then stagger the width. Here is mine
