ZR1 Center Caps
Old Apr 8, 2008 | 01:57 AM
Wingman WS6's Avatar
Default ZR1 Center Caps
Got a set of ZR1's and wanted to ditch the Corvette center caps and put on some center caps that had a Firebird on them. Anyone know if there are some out there?
Thanks!
Old Apr 8, 2008 | 04:13 AM
Donohue96M6Z28's Avatar
if you still have your ws6 wheels... your ws6 center caps should fit.
Old Apr 8, 2008 | 07:53 AM
95GreenZ28's Avatar
Tomz should be able to get you some blank ones then you can decal them
Old Apr 8, 2008 | 09:02 AM
fast377's Avatar
SLP sells them...at least they did last time I checked.
Old Apr 8, 2008 | 03:14 PM
EchoMirage's Avatar
the WS6 caps DO NOT fit. the ZR1 is much bigger. check out either afterthoughtsauto.com or fourthcircledesigns.com. both or one of the should sell the caps, either plain or painted. i think i wound up buying my set from SLP, they were a few dollars cheaper. i got the unpainted ones, sprayed them black, then applied a LS1 bird decal from fourth circle.
Old Apr 9, 2008 | 01:16 AM
Thanks all, I think I'm gona go with the afterthoughtsauto plain ones and do the bird on them!
Old Apr 10, 2008 | 02:59 AM
did a quick search to try to confirm and this is what i found...
https://ls1tech.com/forums/showthrea...zr1+ws6+center
appears as though the 96-00 ws6 wheels fit.
also maybe tomzwheels prices have changed. but to the person that recommennded them. They wanted to charge me ~$25 per centercap last yr when I needed a set of black center caps.
Old Apr 10, 2008 | 08:20 AM
RAMPANT's Avatar
They do fit. These are the only pics I have uploaded.
I used my 99 WS6 centers in mine.
I have SLP chrome ones in them now.
Old Apr 10, 2008 | 03:17 PM
EchoMirage's Avatar
i dont know about yours, but ive tried them in mine. not even close. like donohue said, up to 2000 they can swap. the OP has a 2001....they wont swap.
and $25 PER cap? thats insane. are you sure it wasnt $25 for 4 caps?
Old Apr 10, 2008 | 11:45 PM
Ya, im sure they said 25 each. I was shocked as well. I got lucky enough to find a brand new blank black set on here for 25shipped a few days later .
