any help would be welcomed??????????????????
Old Jul 29, 2003 | 09:39 PM
ron.d's Avatar
Default any help would be welcomed??????????????????
building a 96 camaro-iam a old school guy-i want to fit the rear wheel wells-i want to put a 18x11 torque thurst wheel-without the tire coming out of the wheelwell-i know someone has faced this problem-anyhelp would be appreciated-the 11 inch wheel-is it to wide???????????????
Old Jul 30, 2003 | 09:02 AM
Xsta Z 28's Avatar
Default Re: any help would be welcomed??????????????????
For the Camaro a 11 inch wheel is IMHO too wide. But depending on the offset the wheel may not stick out, the issue will be to prevent it from sticking out, is that is will rubb the inner wheel well. A good offset would be around 55mm.
