Offset question....
Old Apr 22, 2008 | 04:39 PM
SPANKY LS1's Avatar
Default Offset question....
Jeezus, I'm getting ready to order some new wheels, and I'm going crosseyed with all the figuring and measuring, I just wanna make sure that I got this right:
Comparing a 19x11 wheel with a +92mm offset and a 19x11" wheel with a +82mm offset, the +82mm offset wheel would sit 10mm further out than the +92mm offset wheel would, correct?
Shawn
Old Apr 22, 2008 | 04:49 PM
jjordan's Avatar
You are right. Offset is meaured off the centerline of the wheel, a +92mm wheel would have the center 92mm to the outside of the centerline. The +82mm wheel would have the center 10mm closer to the centerline, so the wheel would "stick out" 10mm more than the other.
Old Apr 22, 2008 | 04:54 PM
SPANKY LS1's Avatar
Thank you, thats what I thought.
Shawn
Old Apr 22, 2008 | 06:16 PM
95GreenZ28's Avatar
What is this going on? Different offset than I am used to seeing
Old Apr 22, 2008 | 08:05 PM
SPANKY LS1's Avatar
Old Apr 22, 2008 | 08:23 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Shawn is a fellow wheel *****. Isn't that going to be the 3rd set on this C6? lol
Let me know if you are interested in iForged, DPE Forged, or Fikse. I'm a dealer.
