315s Up Front?
Old May 23, 2008 | 09:30 PM
Ironhead's Avatar
Originally Posted by DAVE00
I assume with 315's this would cause major rubbing issues when turning?
Nope.
Some rubbing under max cornering with a wide square Hoosier? Yes (but none at all with the rounder Kumho 710).
Major rubbing? No.
Originally Posted by SSNISTR
A staggered setup is better. Ferrari, Porsche, Maserati the ZR1, and the ZO6 run a staggered setup for a reason!
Nope again.
Many, many very fast (read: winning) ASP ZO6 drivers are running 315s on all four corners.
In fact, my old set of 17x11s are on a local Z16 car.
Old May 24, 2008 | 12:58 AM
SSNISTR's Avatar
Originally Posted by Ironhead
Nope again.
Yeah, as I said, for a reason....lack of enough grip. Some Ferraris and Porshes that would kill a Vette on a track have as narrow as a 215 up front. When it comes to width up front, wider is NOT always better. But think what you want....you seem to think you know something.
Old May 24, 2008 | 04:08 AM
bluebird71's Avatar
Well it looks like I'll probably just stick with the 275's up front, except I plan on swapping the Firestones for Nitto 555RII's. The whole reason why I even thought about running such a big tire up front is that I have recently gotten more into auto-x and road course and I saw a lot of serious guys running big tires all around. As for as pressure goes, I generally run 35psi in the fronts and 22 in the rears on the street. What is a good tire pressure to run in this set for track use?
Old May 24, 2008 | 08:30 AM
Ironhead's Avatar
Oh silly us. And here we thought all along that our bigger tires made our cars corner harder. I guess timers and data loggers do lie.
You said the staggered set up is better. You said the ZO6 has stagggered tire sizes for a reason. Is it your contention that all those national champs and trophy winners would be faster if they went back to a stock size front?
You're also comparing mid engine and rear engine cars to front engine cars.
You may not be aware of this but mid engine / rear engine cars have, as a percentage of the whole, much more weight on the rear tires. Therefore they need the staggered tire dimensions.
But yes, you are correct on one point. The reason we run a matching large tire up front is more grip. Because, you know, more grip will allow the car to corner harder.
To the OP, if you want to be competitive and the class allows it, 315s all the way around are an absolute necessity. If you only want to have some occasional fun, they're not needed. They're also useless for the street.
Old May 24, 2008 | 11:50 AM
Magnus's Avatar
LS1TECH Sponsor
my wheel widening thread discusses issues you run into when putting 315's all around on lowered cars.
Old May 24, 2008 | 12:11 PM
dailydriver's Avatar
Beat me to the response!!
The other point is that even though the front engined Z06 and ZR1 use a staggered setup in street trim, they are still MUCH CLOSER to a 50/50weight distribution than ANY stock configuration f body could EVER hope to be!!
Old May 24, 2008 | 01:52 PM
staringback05's Avatar
315s up front ....theres no reason for this on our cars...
Old May 24, 2008 | 01:55 PM
Ironhead's Avatar
On the street, yes.
Otherwise, why not?
Old May 24, 2008 | 02:28 PM
Mattism78's Avatar
You do realize not EVERYONE sets their car up for going straight right?
Old May 24, 2008 | 02:29 PM
wabmorgan's Avatar
Check this thread out.....
https://ls1tech.com/forums/showthrea...976&highlight=
Old May 24, 2008 | 04:21 PM
you do realize that putting that fat of a tire in the front is just going to put more strain on the suspension...ps pump, rack, etc...and you realize that bigger is not always better in the front...
alot of guys have no real reason to put those on...they just do it because they want to be different and not understand the consequences of it nor the applications that bigger tires on the front are used for...
just like the kids asking about 335s on the rear of a stock ls1...yes, that should be your first mod , or "dubs" on an f-body
there are alot of other things involved with cornering then tires...and should be address also before anyone moves to that tire size...
as a note i realize what the OP stated...but my comments are for the everyday person
Old May 25, 2008 | 03:45 PM
  #32
99Bluz28's Avatar
Everything has its Pros / Cons! I'm sure we all keep our rpm below 2000, and drive at or below the speed limit to lessen the amount of wear on our cars drivetrain, along with running soft stock height springs and going around corners or curves at 10 mph or less to minimize wear on the Tires, Suspension, Brakes an hubs! ...........
FYI, If you're worried about wearing parts out don't drive your car, or better yet sell it so somebody can enjoy driving it........
Just do what floats your boat!
Old May 25, 2008 | 08:22 PM
  #33
BillS's Avatar
To keep it direct, and out of the e-peen measureing that seems to be going on here.
For autox the 315's will be the biggest improvement you can make after quality shocks. There are negitives to the use of 315's, the wear on the front hubs is greatly increased, and the PS fluid heat goes up.
On the street 315's on the front suck. They tram-line(follow the ruts and crown of the road) to the point if feeling uncontrolable on truck traveled roads. The general strain on the front end parts goes way up. Also your paint will really take a beating.
In road racing the benifit really becomes track dependant. If they can be kept up to temp then they can help, but some have improved lap times by dropping to a smaller width and keeping the tires in their grip range, and lowering unsprung weight.
That being said I run a 315 tire in the front when autoxing and drop to a 275 for street use. And AFS makes a 17x11 rim for the older c4 vette that has the correct offset to run in the front of an F-body, or you can run the GS vette offset and a spacer. It is also allways a good idea to upgrade to the ARP lug studs esp if you are using any spacers.
I have found that all the street 315's and the kumo and nitto 's will go lock-to-lock without rubbing. The hoosier 315 is allmost 1/2 in wider and has some minor rub. Ride height make little difference in the front, atleast for me, but I run GW upper control arms that change the camber curve.
Old May 26, 2008 | 02:43 AM
  #34
Big Bird WS6's Avatar
well the dick Harald cars run 295 front, 315 rear
Old May 26, 2008 | 04:41 AM
  #35
venom ws7's Avatar
^^^ Rear is 335 in those cars and its Dick Harrell.
Old May 26, 2008 | 09:13 AM
  #36
BillS's Avatar
And those are show cars that have been made to be impressive. Most will never see a track for real.
Old May 26, 2008 | 03:12 PM
  #37
lt1noob's Avatar
instead of all this pissing and moaning why dont we just go by what the car will be used for, straight line, or auto x. i think i depends on that more than anything. like ironhead said itd be pointless on the street. but for auto x its been proven over and over again that that wide of a tire up front helps handling. i say we get sam strano in here and see what he runs up front, that may help settle this..
Old May 26, 2008 | 03:34 PM
  #38
bluebird71's Avatar
Strano definitely runs the 315 Hoosier slick up front; that's mostly where I got the idea. For the street however, I will definitely stick to the 275's up front. I am planning on putting the Nitto 555RIIs up there. Are these good tires for street handling? Car is only an occasional weekend driver and almost never sees rain. If there is a better all around set for dry street traction, what would it be? I already have the 555R DRs in back so I figured I would just put the other Nittos up front to save $ and keep the same tire compound all around.
Old May 26, 2008 | 04:34 PM
  #39
if you have the money for just playing around the street...look into a set of michelins...if not nittos in the back and something like a bfg or sumi would be fine for the front
Old May 26, 2008 | 06:18 PM
  #40
bluebird71's Avatar
I was told by a pro auto-x guy that having the same tire compound in the front and rear was the most important thing of all for good handling tires.
