wheel selection...
Old Aug 12, 2003 | 12:28 AM
RAMnGO's Avatar
Default wheel selection...
i am wondering about some weld pro star wheels. Can any1 tell me if for the front 15 x 3.5 w 5 on 4.75 and 1 3/4 back spacing will work without spacers and 15 x 8 w 5 on 4.75 w 5.5 back spacing? also they have different back spacings and if i'm correct this means how far the wheel sticks inward correct?? so a larger back spacing means less tire sticking out but smaller back spacing means it'll stick out further??
Old Aug 12, 2003 | 01:32 AM
slick98ta's Avatar
Default Re: wheel selection...
You got the sizes right,those are the wheels you want to get.
5/16" spacer for the front with no grinding at all.
5/16" spacer for the rear with some grinding or no spacer at all with alot of grinding.I just did alot grinding and run no spacer for the rear.
Your 2 different back spacings for the front and rear is because the front is only 3.5" wide.But yes you answered your question,you are correct
Old Aug 12, 2003 | 02:00 AM
RAMnGO's Avatar
how much clearance should there be between wheel and caliper?
