Postup Pics of Drag setup.
Old Jul 31, 2008 | 08:44 PM
Reject's Avatar
mr lous can i have that link too
Old Jul 31, 2008 | 09:18 PM
bigsticksupra's Avatar
I have Bogarts on mine.
Modifications to fit on car: Torque down the lug nuts
Old Jul 31, 2008 | 09:24 PM
Dragwheelz.com's Avatar
Originally Posted by Dragkid1917
what kindof rims are on that blue z28 with the moser rear?... BTW thank you for finding that stuff on tire rack for me. I did a search and founf mickey thompson tires that are
24x5x15, and dot approved so ill prolly go with them.... Hope they dont look too weird.
Those are the Billet Specialties Street Lites.
There made in a 15x10 7.5" bs for a Direct fit on the ls1/Lt1.
You can see there tucked perfectly.
Old Jul 31, 2008 | 10:27 PM
juiced_z28's Avatar
If I had the budget I would have definitely went with Bogarts or Billet Specialties but my last set (that I just sold) were Weld Prostars 15x10 and 15x3.5.
I seen an earlier post saying that a 5/8 spacer was required on the front to avoid grinding. He may have been confused or maybe he needed that much spacer but I used a 5/16 spacer on my fronts and also on my rears to avoid too heavy of grinding. I also used 2 3/4" long GM wheel studs for safety. A lot of guys still use stock wheel studs with Welds but not enough threads there to turn for me.
I also ran 325/50/15 Goodyear DR's on the rear which required more massaging than fitting the Welds.
Not a bad fit at all. I really like how this wheel/tire combo filled everything in nice in the rear. But like I said there are better wheels that don't require all the BS as you have seen if you have a little extra in your wallet. If not, it's probably even worth saving up to not go through the extra work.
Old Jul 31, 2008 | 10:59 PM
Mr. Luos's Avatar
I like this.
Next time!!
Old Aug 1, 2008 | 10:14 AM
Unstang's Avatar
Bogart DragsOn Stars, 15x10 w/ 275-50-50 MT radials & Moroso fronts.
http://www.fquick.com/garages/viewga...wimg&id=131834
Old Aug 1, 2008 | 11:47 AM
Vicious95Z28's Avatar
i found the mickey thomson ones, but i cant for the life of me find those kuhmos your talking about. Does anyone have a link?
Not a good idea on cars as heavy as they are, the Kumhos won't support the weight and in the end your wheels will suffer for it, if not the whole car because of a wheel failure. Go for the gusto and get the 8 ply mickeys or call Mickey Thompson and see what they say about the Sportsman Radials, they are supposed to be the equivalent of the original Sportsman but in Radial form.
Sorry for the run-on!
And before some guys with 165's start flaming about how they've been running them four 14 years with no problems consider the fact that some guys do have problems and no one is exempt from the possibility, there I said it!
Old Aug 1, 2008 | 11:59 AM
Camaro396's Avatar
Screw the Khumo fronts. I feel much safer going 130mph on M/T tires that were made to do so, than on those that were made for a volkswagon.
Old Aug 1, 2008 | 12:51 PM
Mr. Luos's Avatar
I have Nankang 165's on mine.
I want the MT's though.
Old Aug 1, 2008 | 12:55 PM
Dragkid1917's Avatar
I found M&H racecar DOT skinnies. Made just for racing but DOT approved, for like old school roadsters and whatnot. Im pretty sold on them.
Old Aug 1, 2008 | 12:56 PM
ALLMOTOR346CI's Avatar
Not really a drag setup but i guess ill be a post ***** for a second....
Old Aug 1, 2008 | 03:49 PM
  #32
NOSJNKY's Avatar
Bogart GTs with MT 325/50's and Sportsman front runners
Old Aug 1, 2008 | 07:23 PM
  #33
Tally TransAm's Avatar
Old Aug 1, 2008 | 11:06 PM
  #34
Red 01SS's Avatar
Bogart Welded RT's
Old Aug 1, 2008 | 11:47 PM
  #35
sixvi6-camaro's Avatar
My low buck setup.. Summit Stars MT sportsman fronts and Hoosier DR's rear.
If I had the cash now I'd pick up a nicer set but this gets the job done for now.
Old Aug 2, 2008 | 01:46 AM
  #36
badbird's Avatar
Old Aug 2, 2008 | 03:10 AM
  #37
Toronto_LT1's Avatar
mean looking cars!
do you guy's daily drive on that set up??
Old Aug 2, 2008 | 03:29 AM
  #38
zach_ws6's Avatar
Old Aug 2, 2008 | 09:53 AM
  #39
juiced_z28's Avatar
Here is a pic of my other drag setup guys.
Old Aug 2, 2008 | 10:29 AM
  #40
Camaro396's Avatar
Hahahaahahah Gross!
