Z06 wheels- CORRECT OFSET??
Old Aug 29, 2003 | 02:58 AM
4thGENRETARD's Avatar
Default Z06 wheels- CORRECT OFSET??
I saw some Z06 wheels on RKSPORT.com site.
18x9.5 +57 ofset (Front)
18x10.5 +58 ofset (Back)
Do you think those would fit nicely without sticking out too much??
Old Aug 31, 2003 | 03:21 PM
Xsta Z 28's Avatar
Default Re: Z06 wheels- CORRECT OFSET??
They will fit. They will not stick out. Stcok wheels are around 50 mm. So the wheels will actually move "in".
Old Aug 31, 2003 | 07:02 PM
MJMZ28Cvt's Avatar
The fronts will fit fine but you will have problems with the rears. The fender walls will have to be hit in back there.
Old Sep 1, 2003 | 01:59 PM
They also got 18x10.5 +57mm offset. do these need fender wall hammering also?
Old Sep 2, 2003 | 08:24 AM
Xsta Z 28's Avatar
The closer you get teh wheels to 50 mm or even less, the better the wheel will fit and look.
If a smaller offset is avail, get it. Means less inner wheel well modification. The ONLY thing I HAD to do to my SS with the 18" x 10.5" wheels was the BFH mod to the inner wheel well and reundercoat. Nothing else.
Old Sep 2, 2003 | 05:12 PM
blaSSt's Avatar
[/quote]
Add a 3rd gen 1/8" spacer and you might not have to massage the inner wheel wells. I had to push mine a little bit. (With the spacers)
