Angle Grinding & you
18x10.5 Z06s with 305/35s
I had to grind the **** out of the bump stops, probably a good 1/8th of an inch or more. Lots o' sparks.
Anyhow, I need to clean the car up and get some more pictures in here, but they seems to fit just fine, although I might need to hammer a bit more in the passenger rear.
Also, don't ask why my exhaust looks weird, angle of the picture is off slightly.
I want to know what you guys do when you have your car suspended in the air.
Do your bump stops rub? From what I have gathered from going trough countless threads, it only happens to some people.
I know for sure I could fit bigger tires on the car, and nittos in general run small, but I would need to grind some more because as soon as the suspension is unloaded, bump stops are right in the way.
-Mike
-Mike
And cutting my bumpstops off was, and never will be an option unfortunately.
Too bumpy in AZ (constant construction work everywhere).
Also for the width of my tires compared to some of you guys.... is 12.5 not wide or do the pictures give no justice the width? or both
.. So thats why i had a problem, but uh you shouldntBtw Nice avatar
And does your sig mean NicN tune ? .. Now, this is easily rectified by putting your jackstand underneath the diff (which I was kindly reminded about), however I forgot to mention one thing about that.
One of the only GOOD, trustworthy shops I have had experience with is not a drive-on lift, therefore my suspension is completely unloaded when they are working underneath my car.
I don't think I have heard of a NicN, but this is the NicD I'm talking about
http://gonicd.com/
heres a pic of 325s
i will admit must be the angle in which pics are taken. cause my 325s dont look wide and they are huge
http://gonicd.com/
However, I have had some JARRING hits when these fucktards have done road constuction. I'm talking like 6-8 inch sheer drops from pavement to dirt road.
I do plan on lowering the car eventually (year or so), so it might not be wise to take out the bump stops still?
Also, I will definitely get on posting some more pics... need to wash the car, and take it down to ASU for some sweet parking garage pics (structure 7 for all you people that live in Tempe
