guys with skinnies in here!!
Old Sep 4, 2008 | 09:19 PM
2kbluws6's Avatar
Default guys with skinnies in here!!
looking to order front tires for greg weld 15x3.5 wheels. I know the height (26") but i was wondering the width...probably 4.5? can i see some pics of the fronts for all widths? or is 4.5 the width i need to go...
they will be drag only tires that are put on at the track
thanks
Old Sep 4, 2008 | 09:20 PM
Mr. Luos's Avatar
Are you putting a radial on it??
A lot of guys run 165R15 Kumho's up front.
Old Sep 4, 2008 | 09:27 PM
2kbluws6's Avatar
i was planning on a bias ply. i will be running slicks in the rear. they will see NO street time.
waterbug1999's Avatar
Since its drag only do what I did and get the MTT-3007 tire.. SJM says these are 8 lbs lighter then MTT -1573 which is a DOT tire.
MTT-3007
MTT-1573
Here is how mine looks with my drag set up ready to roll..
Old Sep 4, 2008 | 09:37 PM
Camaro396's Avatar
What he said. 26x4.5-15 M/T ET Front.
Old Sep 4, 2008 | 09:41 PM
Mr. Luos's Avatar
Since we are here....
Difference between the MT front and the Hoosier front??
Old Sep 4, 2008 | 10:06 PM
cowboysfan's Avatar
[QUOTE=waterbug1999;10047786]Since its drag only do what I did and get the MTT-3007 tire.. SJM says these are 8 lbs lighter then MTT -1573 which is a DOT tire.
MTT-3007
I'd get the MTT-3007 if ur only using them for strip....
