tires rubbing
i'm only running 275's.....my wheels are 17"x9.5" with a 7" backspace (which Centerline says equals about a +41mm offset), with GS-D3's. these specs fall within the range posted in the sticky thread:
it's a tiny bit worse on the passenger's side, but it's happening on the driver's side a bit, also, so i don't think just adjusting the PHR is going to make a difference. i'm running Koni 4/4's with Strano springs also, and the rear shocks are set to (i think) 1/2 a turn from full soft. is it possible that just stiffening up the rear shocks will keep this from happening?
i wonder if it's possible my rear Koni's have bombed out on me....i sure hope not....
i'll probably try cranking up the firmness in the rear when i get home in the morning to see if it changes anything at all....i guess if the feel of them doesn't change, they're hosed, and i'll need to get them replaced.....but at the moment, the rear doesn't really feel "floaty" at all, so i dunno....
Unfortunately the only fix is to roll the quarter panel lips, or put in taller rear springs.
