please help i need advice
Old Oct 2, 2008 | 08:02 PM
02 T/A 984's Avatar
Default please help i need advice
im putting bigger tires and wheels on my t/a....just wondering if there will be a performance in grip difference......between 18x8.5 and 18x9.5....or will it be the same.....thanks
Old Oct 3, 2008 | 05:09 PM
copteezer496's Avatar
Should be about the same. It's only an inch so you'd need to be running hard around corners to notice (if any) difference. It also depends on which tires you're going to run. As long as you stay the same brand you have, it won't be ant different.
