Fikse FM5 - Offset ?
Since I have no clue, I need some feedback - I'll be running 17x9.5's on all 4 corners. Also how long did it actually take to receive them once the order is placed, I was told 4-5 weeks - does this sound right ?
Thanks in advance
This is a response I received from them when I inquired. What do you guys think ???
Thank you for your inquiry.
The offset to use with a 17x9.5 wheel on your Camaro is 40mm
- 49mm. Since you are considering one of the wider tires recommended
for the car, use a wheel with a higher offset in this range,
45mm - 49mm both front and rear.
I plan on ordering through Thunder, I'm staying away from the ppl I was originally talking too. Anyways just got off the phone with Paul and he pretty much confirmed the offset you guys gave me.
