Dash/Steering Wheel Removal
Old Sep 16, 2003 | 08:53 AM
LS1x2's Avatar
Formerly 4mulaJoe
Default Dash/Steering Wheel Removal
Do you guys remove the steering wheel when removing the dash? I didn't anc cracked the backside of my dash. Not too bad. I am wondering if I should need to remove the steering wheel to get it in? If so, is a special puller need and where can I get it? Thanks.
Old Sep 16, 2003 | 11:57 AM
Scalpel's Avatar
Default Re: Dash/Steering Wheel Removal
No need to remove the steering wheel. Just remove the 4 nuts holding the steering column in place and let the steering wheel/column hang down, gives you enough clearance.
