F*cking wiring nightmere
Old Oct 28, 2008 | 08:50 AM
94lt1m6's Avatar
Default F*cking wiring nightmere
When i bought my car back in april, a wire to the amp kept catching on fire, my cutout wiring caught on fire, my radeo shuts on and off at will, wont start untill i hit the battery sometimes, my windows wont role up at random times, ABS/TCS shut off after any bump voltage bounces everywere......you get the picture.
I pulled out ~60ft of wire going? and doing? pulling all that wire fixed the fire problems, my battry tested bad, i got a brand new one and that didnt fix the prob.
Anytime something stops working it seems to be when the car is warm only, and when i drive over a bump. I cant find any bare wire anywhere that could be causing shorts?
Advise?
Old Oct 28, 2008 | 09:43 AM
BIG_MIKE2005's Avatar
check all your actual battery harness connections. Mine was in bad shape so when I did my H/C install I put in a new one.
Old Oct 29, 2008 | 05:28 PM
94lt1m6's Avatar
Ok, also something that im sure is related, in the morning and only when its cold my subs will sound fine and everything is all cool, then about 4-5 mins when it finally starts to warm the subs go nuts, like one of the wires is rubbing on something and anytime i hit a bump in the road it sounds like they hit.
Old Oct 30, 2008 | 10:31 AM
samson_420's Avatar
Most likely a bad ground somewhere. My old did that, just a little. I never found the source.
