Monster tach trouble shooting
Now on to illumination. This is where I'm trouble shooting. I ran the wire down & piggy backed off my HVAC lighting which is also piggy backed to my Humount. All the illumination for the Humount & HVAC controls works perfect. So I know it's a good source.
This tach has "around the dial" lighting instead of "thru the dial" so there is a little bulb holder on the face of the tach. I have pulled this out & checked the bulb. filament is good still. Tried flipping the bulb around, tried flipping the bulb holder around & tried a LED bulb. Nothing has worked. I cannot get this thing to illuminate at all.
Has anyone else running one of these had this problem. I already did a search & everyone with issues had it hooked up wrong from the beginning. But this doesn't seem to be the case on my install. I'm wondering if something in the socket itself is messed up. I see there is 2 tiny screws on the face holding the little black piece on that houses the **** to set the shift light & the bulb for illumination. I was thinking about removing it to see if the wires are all still ok goin to the bulb socket.
I'm open to any idea anyone might have or info if anyone has had this same issue. I'm very happy with the tach during the day but I want it to illuminate at night so I can read the damn thing. I can definetly vouch the stock tach is way off on a solid H/C car now.
There are chips that take care of this:
http://www.scribd.com/doc/24073/7407
Depending on how much current the lamp requires, a transistor buffer may be required. (Very simple)
Then he should be able to hook up the illumination wire to +12 and the thing should light up.
Or run a small bulb from the spliced HVAC illumination wire and see if it is lightable and dimable.
One is funky.
I'm gonna try splicing the illumination into the power for the tach just to see if it'll light up with straight power source. If it doesn't then I know something is wrong inside the tach.
