Sail subs dont work...Help!
As far as your sail panel subs not working...they could be blown (especially common in Camaros), they could be disconnected, or the previous owner may have put some kind of incompatible replacements there. The first thing to do is pull them out and check their condition and connections.
also, there is a thing that runs my aftermarket amp that is wired from the left rear speaker. i know this is how my amp gets the signal to work cuz it is hooked up with rca cables. but there are also wires coming from that, that are cut and not hooked up. this thing is called an andjustable output adapter. is this how you guys hooked up your amp also? the last pic shows this.
it looks like somebody did a whole lot of other stuff to this car with their audio setup or something. i know its hard to see in the pictures but if anyone knows if my setup is normal, or if this has anything to do with my sail subs, or what all that junk is...let me know. thanks in advance.
The box is a LOC (line out converter) that converts speaker level signal to line-level (pre-amp) signal for use as input to an aftermarket amp.
Neither has anything to do with the sail panel subs unless the previous owner rewired the subs from the factory amp to an aftermarket one.
oh DUH! lol isnt that for the cd changer?
