My keyless entry is going nuts...help me.
Old Nov 8, 2008 | 11:29 AM
texasglock23's Avatar
Default My keyless entry is going nuts...help me.
Today I noticed a low rear tire so I ran up the street to add more air. Didn't fool with anything at all other than that I came right back home. I started fooling around the house with chores and managed to hear my alarm. Ran outside and sure enough the horn was blasting. Neighbors were out ao I knew no one had fooled with it. It had just began to rain (small shower). I disarmed and re-armed the car. Within 15 seconds or so it began again. Repeated the same procedure and damned if it didn't go off again. So I just locked the car from inside and it started going off after that. So as of now I just left in unlocked.
Info on the car: Bought the car about 3 months ago max. Done nothing to it as of yet. It has rained the laste few weeks, and right after buying the car. Never have I had this problem before. Can anyone chime in and help me?
Old Nov 8, 2008 | 11:34 AM
99FormulaM6's Avatar
Check the adjustment for the shock sensor. Its where the factory amp is in the back by the spare tire. Its a small black box about the size of a box of matches. It has an adjuster on it, and usually they say not to mess with it from the factory, but yours might need to be adjusted.
Old Nov 8, 2008 | 11:36 AM
Alright I will go try that now
Old Nov 8, 2008 | 11:47 AM
Didn't help. The sticker was still attached so it had never been fooled with. I broke the seal and dialed it down a small turn first, then all the way down. Still goes off.
Old Nov 9, 2008 | 09:38 AM
WhiteBird00's Avatar
Ungrounded Moderator
Try unplugging the shock sensor. They have a tendency to fail due to moisture. If unplugging it takes care of the symptoms then you can decide whether you want to replace it or just leave it unplugged.
Old Nov 9, 2008 | 10:03 AM
I went ahead yesterday and unplugged it. I am looking at getting a new sensor. Thanks for the help.
