Problem w/ factory shock sensor?????
Old Sep 24, 2003 | 04:10 PM
seadoo's Avatar
Default Problem w/ factory shock sensor?????
I cant seem to get my shock sensor to work.. I have the factory alarm with the shock sensor, and I set it all the way to max. sensitvity level, but I can hit the car, shake it hard and still wont go off. but if I tap the little box itself it blinks. WHY????????? the book says that a gust of wind can set it off when it is like that. Please help me. I want to set the sensor to pick up if someone hits my car. PLEASE!!!!!!!
Old Sep 24, 2003 | 09:12 PM
VIP1's Avatar
Copy & Paste Moderator
Default Re: Problem w/ factory shock sensor?????
You are not alone. My car was stuck on the driver's side one evening causing $1000 in damage and the alarm did not go off. I took it to the dealership to have it checked. It was on its max setting. If you kick the tires or if a freight train goes by, the alarm sounds. If you hit the body...nothing!
--VIP1
Old Oct 12, 2003 | 05:47 PM
itchygomey98's Avatar
I had a problem with mine a while ago. In the Camaros, the shock sensor is in a pretty bad place. If it rains and you open the hatch, water comes off of the hatch and some can run down onto the sensor. I opened mine up (just pry it open) and it was full of fungus. I cleaned it up with alcohol and it's worked fine since. I don't know if this is what your problem is, but it's worth a shot.
PS - I don't mean to point out the obvoius, but you do have the shock sensor activated right?
Old Oct 13, 2003 | 12:48 AM
MadIceV8's Avatar
Customizing Director
--VIP1
Same problem here.
Old Oct 14, 2003 | 11:38 PM
WHITE_02's Avatar
Go with an aftermarket alarm.
