Window motor swap Instructions = A+!
Old Oct 2, 2003 | 01:08 PM
UGOT8's Avatar
Default Window motor swap Instructions = A+!
My driver side window motor went out [suprised? no].
I got a new window motor for my B-Day [great present!] and instead of paying someone $100 to swap it out -- I decided to try it on my own.
I looked at instructions here [ Power Window Motor ] for help, and although these instructions were for the camaro and not the trans am, they were excellent.
I've heard a lot of bad things about doing this youself, but if you take your time and keep your cool, it is very simple and will save you $50-100 on repair bills.
One point of caution -- DEFINITELY wear protective gloves and cover your arms as the website suggests. The door panel is made of unfinished fiberglass -- and it WILL cut and splinter your skin.
Anyway -- these instructions are given an A+ from me.
Thanks a lot to the writer.
::Austin::
Old Oct 2, 2003 | 06:59 PM
firebirdude's Avatar
Default Re: Window motor swap Instructions = A+!
What window motor did you use? The stock GM one? I'm looking for the strogest and fastest motor that will fit the car. I don't care about the cost. I'm sick of this....
Old Oct 3, 2003 | 10:56 PM
14u2nv's Avatar
I used a seimens from Autozone for $70.00 and it came with a lifetime warranty.
Old Oct 6, 2003 | 11:42 PM
UGOT8's Avatar
I used the $50 one from Autozone .. its a little bit more noisy than stock but its faster than my other window motor ..and it too has the lifetime warranty
