AMP Wiring question....
Old Jan 10, 2009 | 01:54 PM
RonniesLS1's Avatar
Default AMP Wiring question....
I search (a little not a lot) and found only one answer about about wiring the power wire from the battery to the amp through the firewall.... I looked where they said but it was in a 98' firebird, I have a 2001 formula and need help! where can I feed the guage wire through the firewall? thank you!
Old Jan 10, 2009 | 02:11 PM
pentavolvo's Avatar
its same on all 4th gen fbodys, just unbolt pcm and slide it up and bam u have full access
Old Jan 10, 2009 | 02:17 PM
vjo90rs8's Avatar
you don't even need to unbolt the PCM. I took a screwdriver and poked a hole in the grommet (to ensure the power wire will still be surrounded by rubber) from the inside of the car. Just remove the passenger side kick panel (5 screws) and the passenger side hush panel (2 push pins) and reach to the far corner and you should be able to feel it. Then I pushed the wire through the opening. If you push enough wire through the hole you should be able to grab the wire from behind the PCM without having to remove the PCM.
Old Jan 10, 2009 | 02:23 PM
Engine_HP's Avatar
if u are going to remove the pcm dont forget to disconnect the battery
Old Jan 10, 2009 | 02:31 PM
pentavolvo's Avatar
i never unhook pcm just lift out and lay on side
Old Jan 10, 2009 | 03:10 PM
RonniesLS1's Avatar
thank you!!!! yeah I just layed it on the side but I have to disconnect the battery anyway to hook everything up! but thank you! i'll summit pics of everything when i'm done
Old Jan 16, 2009 | 09:31 AM
Dip Stick's Avatar
ya I need to do the same to run a few switch wires. I was thinking of drillng my own hole and using rubber grommets, but cant seem to find them anywhere.
