HU replacement causing battery to drain
First off, I've replaced the factory mosoon with a Clarion HU. Had several issues in getting wiring correct, but eventually got it to work. Up until this time, had no problems. Since there isn't much room back there to stuff all the wires, I decided to remove an unused AULOC spliced into the speaker wires and radio ground. I cut each wire at the splice, and then taped up each end. As I was moving the wiring harness, I noticed that there was static coming from my rear speakers. The thing is, there was no radio installed, and the ignition switch was off, although wiring harness for the new HU was connected, but the HU was not. The more I moved the harness, the more static in the rear speakers. WTF?
So, I reconnected the AULOC, and that problem went away. Completed installation of the HU, and started the car to check everything out. The gauges acted as if I had disconnected the battery, which I didn't (wondering how removal of the AULOC had anything to do with this). The car started, and the HU worked fine, with good sound from each speaker. I also noticed that my trip odometer was now zero'ed out. Well, put everything back together. Went to start the car this AM, and the battery was now almost dead.
I've taken out the new HU, and removed the new HU wiring harness while I recharge the battery.
What do you think are causing these two issues?
Here's how I've wired the HU.
Aside from the speaker wires, here's what I got
camaro adaptor HU
Constant
power Orange yellow Red
Ignition
power Yellow Red Red
Dimmer Gray Orange/white Orange/white
Ground Black Black Black
One thing that comes to mind as a source of the problem, though I don't know what this would do, is that I spliced in the ground wire from the HU to the adaptor, leaving an exposed pigtail in the event I needed to an additional ground.
Any thoughts?
Thanks
That part is working correctly. With the HU switched on, I shut off ignition, and the HU stayed on, as it's supposed to. I opened the door, and it shut off. I tried to switch it back on, and it wouldn't, until I started the car.
I reconnected everything after charging the battery, and it all seemed to work fine. Car started, HU went on when switching it on, off with ignition off and door opened. I noted that when I worked to disconnect the HU connector from the camaro connector, I got a little static in the speakers again - this is with ignition off, HU off. Restarted car, all OK. Reconnected everything, checked HU operations, all was well. Disconnected, and this time, no static.
For tonite, I've kept it out of the car, seeing if the battery drain is due to something else.
Thanks
Is there any way, with the battery connected and ignition off, that I can determine which circuits are draining the battery?
If that makes the light go out of really dim then it is in that circuit. Put the radio fuse back in and start checking the circuit until you find what is causing the drain.
Thanks again
More later.
Still haven't figured out why;
- sound coming out of left rear speaker when moving HU wiring harness around, with ignition off and no radio connected - maybe messed up adaptor, as all the splices are clean, connected, covered with heat shrink and tape
- popping sound coming from speakers when connecting new HU to wiring harness. maybe coming from monsoon amp?
- with monsoon HU back in car, see if there is still something causing battery to drain.
I've left the stock monoon amp installed and wired, wanting to continue to use it with the new HU. I didn't think the amp has been involved with issue at all, until now. (I've also seen one other member here that had a similar problem in 2007 and have sent an email to find out how that was resolved). This is a convertible, and there is a grey wire in the harness that has no corresponding wire for the new HU associated with recognizing that an amp is in the circuit. Apparently, that is irrelevant. What is relevant is the fact that the amp is powered on by the presence of a signal in the speaker wires. IN addition, I noticed that the left rear speaker (the one I've been getting noise from when moving the wiring harness around) pin in the adapter was loose. I took the adapter apart, reset the pin, and it's now firmly installed in the adapter.
My thinking is that the loose wire in the adapter was somehow contacting the power lead (On the same side as the power wire in the adapter) when moving things around, turning on the amp and accounting for the sound coming from the speakers despite the fact that there was no HU installed. That also accounts for the popping noise coming out of the speakers when connecting the new HU to the wiring harness while the battery is connected.
It seems that the loose wire in the adapter was keeping a signal going to the amp, keeping the amp turned on and thus draining the battery (an old battery and cold weather made this even worse, killing the battery) - Anybody have any thoughts on this assumption?
Is there a separate fuse for the stock monsoon amp? If so, I might be able to determine if that's still a problem. I'm hoping that by redoing the adapter splices as a precaution, doing all the installation work with the battery NOT connected, that this will be resolved, pending what I hear from the other board member.
Moral to the story is:
1 - when instructions say to disconnect battery, do it. I didn't, and that is likely one of the problems I experienced
2 - check the wire connections on adapters. One was loose due to my playing around with it a little, and this is also the likely cause of the problem too, as it appears that the loose connection was somehow touching the battery power line, causing the sounds I was hearing from the speaker, and leading to draining an old weak battery, causing its demise.
Regards to all who read through this thread.
I always use GOOD crimpers, not autozone crimpers. There is a big difference in the way they crimp the connectors. Then heatshrink over them at least an inch on either side of the connection. On top of that I use large heatshrink to bundle all of the wires together.
Here are good crimpers that I am talking about. Actually the ones that are sitting in my toolbox.
