To Much Voltage I Need Help
Old Jan 21, 2009 | 12:35 AM
XpEdItIoUs's Avatar
Default To Much Voltage I Need Help
I just finished my car and today was the first time I took it out for a meet. On my way there my cars voltage was at 15-17 volts and my check guages light was on. I have a spal 16" fan, twin 355 fuel pumps, and i use a injector controller. My alternator is stock, Should i replace it with a 200 amp alternator? or do i have a electrical problem somewhere? BTW my battery is in the rear and i have a cut off switch.
Old Jan 21, 2009 | 08:01 PM
99345hp's Avatar
voltage regulator in the alternator might be going bad. It might also be that it is trying to keep up with with huge draw you are putting on it. I dont think it would hurt to upgragde the alternator with all those extra electronics you have going on there.
Old Jan 21, 2009 | 08:20 PM
pentavolvo's Avatar
measured with an actual voltmeter or dash guage?
Old Jan 21, 2009 | 08:26 PM
XpEdItIoUs's Avatar
volt meter says 14.7
