Non-GM stereo question
Thoughts? Could this be a power or ohmage issue? I'm not too great with the stereo/electronic stuff. Here's the head unit:
http://sm.crutchfield.com/p_158GT330...0.html?tp=5685
Thanks, guys.
EDIT: Uploading a video so you can hear it...http://www.youtube.com/watch?v=vm_dwRx02vQ
Didn't come out great but you get the idea.
The common ground speaker wiring configuration is not common in modern vehicles. However, certain auto
makers still use common ground wiring for some of their vehicles (who knows why).
Common ground wiring configurations use individual (+) positive speaker wires to connect to each speaker but they use the
SAME (-) negative wire to connect all speakers (many older cars actually connect the (-) negative terminal of the speaker to
the metal of the car. This was acceptable for when car stereos were low powered, but as car stereos increased in power, the
need for floating ground amplifiers increased.
Basically if you do indeed have common ground you can either 1) re-wire the entire car, or 2) Order whats called a PSI2 from peripheral electronics that allows you to interface into the vehicles system without acutally re-wiring the entire vehicle.
Not sure if this is what you are dealing with but I hope this helps...
Thanks again for the responses!
