light issues are radio install
Old Jan 28, 2009 | 02:12 PM
2002redhawk's Avatar
Default light issues are radio install
have a 02 trans am firehawk. Well i got a radio installed in it, and everything works fine. However now i notice when i go to turn the lights on the air/temp/and speed insturment panel lights dont come on. I looked and all the harness are connected. Where are the fuses located? the only other thing i can think of is the bulbs burnt out?
Old Jan 28, 2009 | 02:33 PM
meangreenchevy's Avatar
Illumination is prob hooked up wrong... its the orange/black or orange/white wire in the aftermarket harness adaptor(assuming you didnt cut the factory plug) best thing to do is not hook it up at all... not sure what fuse it is but take a multimeter and test the fuse you will eventually find the blown one
