Been a while since I've wired subs up
Old Feb 12, 2009 | 01:07 PM
whiteboycntdnce's Avatar
Default Been a while since I've wired subs up
I bought 2 6.5 subs to replace the ones in the sail panels, they are a 4 ohm dual voice coil setup. I bought an amp from a dude off here (a small kenwood) that I'm going to run RCAs to the back of my new deck...
Question is this, do I just run 2 ground and 2 positive wires off of each speaker the to the amp? The amp is only a 60x2 so i was thinking about bridging it since the subs have a max 175 rating. How do I run the speaker wire to the amp if I do that? If I remember correctly, I just take all the negative leads on put them on one (-) terminal on the amp, and do the same for all the positive leads to the (+) terminal.
I dunno if this is important or not, but when I had the new JVC deck installed they installed new speakers and ran their own wire, basicaly... factory amp is still in the car, but not being used I guess.
Old Feb 12, 2009 | 03:33 PM
DoingBadThingsIsFun's Avatar
One - and one + of EACH sub (you have to run + and - from one side of the sub to the other if there are in fact dual voice coil like your saying.) then run each sub to the amp on the BRIDGED setting. If the sub is wired incorrectly it will vibrate slightly and not produce any sound (i wired mine wrong like this on accident no bigger but was good to know). yes then just run RCA's (plugged into the SUB output on the back of the deck) and remote from your deck to the amp, the speakers and wiring that the other person installed has nothing to do with the sub.
Old Feb 12, 2009 | 04:33 PM
vjo90rs8's Avatar
1. take both + leads of one subwoofer and solder them together
2. take both - leads of the subwoofer and solder them together
3. repeat steps 1 and 2 on the other subwoofer
*now both subwoofers are wired as a 2ohm load
*if you bridge the amplifier you probably need to use a 4ohm load
4. run a positive and negative wire from each subwoofer to the amplifier
5. in order for the amplifier to see a 4ohm load you need to wire both subwoofers in series.
6. take the positive wire from the drivers side subwoofer and plug it into the positive bridged terminal of the amplifier.
7. take the negative wire from the drivers side subwoofer and solder it to the positive wire of the passenger side subwoofer.
8. take the negative wire from the passenger side subwoofer and connect it to the negative bridged terminal of the amplifier.
9. set the gain by turning the volume up to 3/4 of max, play a 60Hz test tone, use a digital voltage meter to measure the output of the amplifier, turn up the gain until you read 26.5V, this will give you 175W which will be 87.5W per channel, then you can fine tune the settings.
