Amp
Old Feb 24, 2009 | 01:53 PM
V6Bird4eva's Avatar
Default Amp
Hey guys,
Im gettin a MTX T7510-44 Thunder7500 10" Super Woofer
Here are the specs
Specifications: *Power handling: 400 watts RMS
*VCdia: 2.375"
*Impedance: 4 ohms per coil
*Re: 1.54 ohms
*Frequency range: 47-150 Hz
*Magnet weight: 93 oz.
*Fs: 46.54 Hz
*SPL: 90.63 dB 2.83V/1m
*Vas: 0.487 cu. ft.
*Qms: 4.50
*Qes: 0.98
*Qts: 0.81
*Xmax: 16.51 mm
*Dimensions: Overall Diameter: 10.73", Cutout Diameter: 9.15", Mounting Depth: 6.70
Could someone please explain to me how I determine which amp to get? All the damn numbers are making my head spin.
Old Feb 24, 2009 | 02:01 PM
vjo90rs8's Avatar
Kicker ZX400.1 is one option, delivers 400W+ at 2ohm (you can wire the subwoofer for 2ohms)
Old Feb 24, 2009 | 02:24 PM
V6Bird4eva's Avatar
so when u match up subs with amps all u need pay attention to is the wattage and the ohms?
Also whats the difference between running a sub at 2 ohms versus 4ohms?
If you haven't figured it out yet im building my first system and don't know a lot.
Old Feb 24, 2009 | 02:49 PM
ImpSS07's Avatar
Yes, watts and ohms, mono block or multi-channel also brand quality! Amps have different outputs at different ohm loads. 2ohms puts out more wattage than 4ohms. 4ohms is usually what the RMS wattage is rated at. Also are you only getting 1 sub?
Old Feb 24, 2009 | 03:53 PM
V6Bird4eva's Avatar
yup. I plan on also buying a stealth box from kee audio.
