sub not working
Old Feb 25, 2009 | 07:15 PM
2002redhawk's Avatar
Default sub not working
Well i know the subs work. I have everything hooked up correctly except the rc cables. Heres the problem i have a jensen uv8 flip out. It only have one subwoofer outlet port. I've tried hooking that one port up and just running one sub and it didnt work. I've also tired hooking up my subs off the rear audio l and r outputs and that didnt work. I dont know what it could be. Any ideas?
Old Feb 25, 2009 | 07:21 PM
4THGENCAMAROFAN's Avatar
Take a voltometer and make sure you have power at the amp's positive terminal, make sure you have a good ground, make sur your remote turn on wire is hooked up too. If you test the positive terminal and you don't have power check the battery terminal and check you in-line fuse or ANL fuse, which ever you have. Hope this help...good luck.
Old Feb 28, 2009 | 05:25 PM
95TAJade's Avatar
4thgen's got it right on the nose!
Old Mar 1, 2009 | 04:16 PM
yay!!!!!!!!!!
Old Mar 1, 2009 | 09:13 PM
layitlow's Avatar
i had the same flip out and i used a splitter on the sub output
