Big electrical problem need help asap
Old Oct 14, 2003 | 06:25 PM
AshF's Avatar
Default Big electrical problem need help asap
Ok, right now my car is recieving little to no power from the battery. I mean NOTHING has power. I was in a carwash today, and as always I turned off the engine, and just turned on accessory power so I could listen to the radio. Carwash ended, and I attempted to start the car. As soon as I turned the ignition, all power died, and that was that. The battery is fine, I've checked it for a charge. I have no idea what is wrong or how to fix it.
Old Oct 15, 2003 | 11:39 AM
Beeler422's Avatar
Back in the staging lane
Default Re: Big electrical problem need help asap
so, if you turn it off, and then back to acc, does everything come on, or is it all dead still?
Old Oct 20, 2003 | 10:42 AM
2KThunder's Avatar
Do you still have a problem, or did you correct it?
John
Old Oct 20, 2003 | 03:46 PM
ZigZagZ's Avatar
The first thing I would look at, (assuming the battery is okay), would be the battery cables, and terminals.
Old Aug 29, 2004 | 06:07 AM
transambandit's Avatar
check your alternator, had the same problem on my old mustang
Old Aug 29, 2004 | 09:33 AM
VIP1's Avatar
Copy & Paste Moderator
You are a little late. I doubt his car is still sitting at the car wash place after a year.
Old Aug 31, 2004 | 06:34 PM
sammyschevy's Avatar
i believe things have moved on.
