I screwed up
Old Mar 17, 2009 | 06:45 PM
taram118's Avatar
Default I screwed up
okay i messed up big time. i put new gauges in my car today and had a brain fart and forgot to check where the needles were before. so everythings back together and i know i didnt get them back where they were. any ideas? or am i screwed? any help would be greatly appreciated.
Old Mar 20, 2009 | 08:10 PM
futuref-body's Avatar
after you run your car a while stick your temp needle back on to right below 210. oil-guess your normal oil pressure? rpm-your average idling rpms, mph should sit right on the bezel, battery-guess your normal voltage and then gas-either wait till you fill up or run out, your choice sorry not to much of help but thats what i would do at the moment in your situation. not sure about this but MAYBE if you get a handheld programmer it should be able to tell you the rpm, oil, volt, and temp.
Old Mar 28, 2009 | 01:40 AM
Silver Rocket's Avatar
run the car to normal operating temp and fill the gas tank
