Tweeter Install Question
Does anyone know for sure?
If it is the crossover should I just replace it with the crossover that came with the Components?
Is there any way to adjust that filter? My Monsoon system sounds like it is missing some of the "high-midrange" frequencies. It sounds very "top-and-bottom" with nothing in the middle. None of the speakers are blown I think. Could this be it?
The tweeters in a Firebird are not powered by the amp so that certainly isn't the problem. Try playing around with the equalization to see if that solves the problem. I have also heard of some Firebirds having the high-pass filters go bad.
If you really want to use the crossover, use it as just a high-pass filter. Connect the factory tweeter wires to the crossover input and the crossover's tweeter output to your new tweeters. Don't connect the crossover to the woofers in any way.
