Car died! Need help!
Old Apr 18, 2009 | 07:41 PM
z2895's Avatar
Default Car died! Need help!
my 1995 camaro z28 was running just fine. i let it sit for 1 hour, go try to start it and it just cranks over. turns over just fine. There is no spark. my distributor should be o.k. it was replaced not to long ago and with a new fuel pump. I have no spark coming from my coil. Now when i check for power, i got a tool from a garage. i put it on the negative on the battery and check the wires going into the coil and ignition modular. I have power in one pink wire(one wire plug out of two) but wen i check for spark OUT of the coil i have nothing! so.. i replaced the coil along with a new ignition modular and it still will not give me spark! any idea what is going on!
