Driver door speaker VERY quiet
Old May 12, 2009 | 08:30 PM
OffspringZ28's Avatar
Default Driver door speaker VERY quiet
almost mute. I only found this out by switching the fade/balance to front right and there is almost NO sound coming from it. Speaker is CDT and i am pretty sure the wiring is right. the pass door speaker sounds fine. any ideas? totally drawing a blank here
Old May 12, 2009 | 10:34 PM
habeba86's Avatar
Could be alot of stuff.... Are the speakers ran off an amp? If so , I would check the rca's on the amp. Then I would check to make sure the wiring is still godd at the crossover.
Old May 16, 2009 | 01:24 PM
it's a direct factory replacement speaker. stock head unit and everything.
Old May 16, 2009 | 08:06 PM
bump
paging KEE audio
Old May 17, 2009 | 08:45 PM
KEE AUDIO's Avatar
If the passenger side is working fine then either the speaker is wired wrong...reversed the polarity possibly, or the speaker might be bad somehow from the factory. Rarely happens but it can. Reverse the speaker wires and see if that helps. If not then test the speaker on a known source to see if it works...like a home audio system. If the speaker is bad for some reason, CDT will replace it no problem.
Old May 17, 2009 | 09:23 PM
will do. didnt even think to run it on a home system. thx
