Overdrive my HO alternator?
Old May 18, 2009 | 08:58 PM
shoemike's Avatar
Default Overdrive my HO alternator?
I logged battery voltage and above 4800RPM
voltage drops to just around 12.5v.
Idle and below 4800RPM are fine. (13.5v)
This is with a 200 AMP alternator,
2AWG battery cables, an Optima red top that are less than a year old,
and an UD pulley.
My stereo system is upgraded but nothing special,
and I power a laptop with V2 Flashscan for data logging.
Should I change the alternator pulley?
The stock alternator pulley is around 11% bigger than the Load Boss.
Old May 18, 2009 | 09:24 PM
dragonrage's Avatar
I bet you gained a whole ton of power with that UDP. I'm guessing around 0%.
Old May 18, 2009 | 10:57 PM
shoemike's Avatar
Actually it replaced a broken stocker.
IIRC there was a dip in voltage with it and the stock alternator.
I'm wondering why there is a drop at high RPM.
Old May 19, 2009 | 10:15 AM
BRD-PREY's Avatar
Isn't this backward?? Voltage should be a problem at lower rpm not higher right. If you were going to have a problem.
Old May 19, 2009 | 03:18 PM
shoemike's Avatar
I suspect my belt is slipping at higher RPM.
