Firewall access?
Old Jun 2, 2009 | 01:06 PM
RealLiveMD's Avatar
Default Firewall access?
Are there any firwall access ports with rubber grommets on a 02 ta or will I have to make some. If so, where are they?
Old Jun 2, 2009 | 01:45 PM
ItsNotStock's Avatar
Yes, there is a firewall grommet that the engine wiring harness goes through to connect to the interior harness. It is located on the passenger side facing side, behind and underneath the pcm. To access it I had to detach the pcm and move it out of the way.
Old Jun 2, 2009 | 01:49 PM
RealLiveMD's Avatar
Thanks, I needed that.
Old Jun 22, 2009 | 11:02 PM
Blevinator's Avatar
I used the same grommet. Taped the power wire (4 guage) to a coat hanger. Poked it through, then used a second coat hanger to hook it and pull it up!
