Double din mount
Old Jun 11, 2009 | 01:36 AM
BRD-PREY's Avatar
Default Double din mount
Well I was trying to leave the ledge in like White Bird suggested. Took the sanding board to thin it down and just touched it and it cracked. 6 hours later, 10 bucks in sheet metal and a $2000.00 tig machine and presto a double din mount for my WS6
Ed
I'm going to put grommets in the holes so it will sit on rubber. Paints drying.
Attached Thumbnails Double din mount-mount-ready-paint.jpg   Double din mount-mount-ready-paint-2.jpg   Double din mount-craacked-ledge.jpg
Old Jun 11, 2009 | 02:05 AM
evilZO6's Avatar
I f***** up my shelf too, so i just remoed it and it gave me extra room. I made a similar mount, but in the end, just the side mounts were needed. Looks good though. What are you doing for your bezel?
Old Jun 11, 2009 | 05:58 AM
BRD-PREY's Avatar
Already filled the grooves in from the back with hairy bondo, should have the radio mounted tonight and starting to grind the bezel.
I built the shelf because I didn't want all that weight on the back, I bent the original metal in that stock pin mount into kind of a spring that pushes up in the back, plus the piece get support across the whole front from the A/C controls.
Did you do you bezel yet?
Ed
Old Jun 11, 2009 | 09:59 AM
VIP1's Avatar
Copy & Paste Moderator
That metal frame looks really nice.
One question though, why were you sanding the plastic shelf? I didn't have to touch it to fit a double-din in my Formula. I trimmed the top part of the opening, as per WhiteBird00's recommendation.
(WhiteBird00 took that picture, but I'm re-hosting it on my domain.)
Here is my write-up:
https://ls1tech.com/forums/stereo-el...installed.html
Old Jun 11, 2009 | 01:40 PM
BRD-PREY's Avatar
Yea I see, I actually met with Whitebird00 and we talked about it. I could have swore I read to file a little bit off of the shelf. I already filed the teeth off you had circled and the unit was too tight. Oh, well only 6 or so hours of my time. Its re-run season anyway.
Duh
ed
Old Jun 11, 2009 | 02:45 PM
evilZO6's Avatar
i also trimmed the upper part of my dash, but with that cage sitting in the way it was still scraping so i tried to modify t but it cracked. It was so britlle i couldnt imagine it actually providing support. I took that stock rear mount peice and bent it and made a tab for it to screw into. I took a completely diffferent approach with my bezel. I closed in the air controls so that the whol bezel is one solid peice with the opening for the radio, and 3 cicular openings for the air conditioning controls. IM not done yet but clese, and i have a friend who is going to produce them pretty cheaply. He can 3-d scan it and simply print them from his 3-d printer. Cheap material so it should be pretty cheap to reproduce them. He also has a vacuum molder but we dont know if its necessary to go that route
Old Jun 11, 2009 | 06:15 PM
BRD-PREY's Avatar
Send me a picture when you get it.
Well need to go get busy.
Ed
