where exactly is the braided engine to chassis wire
Old Jun 27, 2009 | 09:19 PM
BRD-PREY's Avatar
The charging system needs to be tested by a shop. A large test load is put on the system to see if the alternator can handle it. I suppose if you knew someone an o'scope they could check the output of your alternator for stepped DC if my memeory isn't too shot thats the result of only half of your rectifier working.
Ed
Old Jul 2, 2009 | 07:21 AM
badmfkr's Avatar
Default results of alt.battery,starter & drain test
I had the car checked here are the results
battery test
good battery
voltage 12.99V
mearsured 717CCA
rated 600CCA
temperture 127 degrees F
starter test
cranking normal
voltage 11.44V
amps 50.5A
time 1.628
charging sys.
no problems
no load 13.88V -7.8A
loaded 13.740 V -14.6A
drain test
0.09A pass
I'm thinking I have ruined the AC.
Thanks
Old Jul 2, 2009 | 04:24 PM
flak_monkey's Avatar
On my LT1 it's by the passenger side motor mount. Probably diff on your block. I've not big 3 on an LS1 yet.
