Convert from Power to Stubby Antenna?
How do I go about mounting a non-powered stubby antenna to that base?
How do I hook up the antenna wire to the stubby antenna?
Here is a link to the Antenna i bought: Stubby Antenna
and no I didn't do any research before-hand. I was thoughtless.
Do you know that you can get replacement power masts? They will probably run you less than what you need to put a fixed mount together.
You can also install a hidden antenna and skip all the stuff in the back.
More on the antenna mod known as Bitviper:
https://ls1tech.com/forums/search.php?searchid=8233889
After a while I took off the original antenna shown in the first pic and added a lil longer antenna which I like better:
