Need HVAC Schematics
But yeah, I'm not looking to manipulate/bypass anything beyond the controls.
I know that A/C is available in the Max, Norm, Bi-level, Vent and Defrost positions so I don't see why Heat/Floor would be the only position that wouldn't have it.
Notice the options are a bit different than the print.
The colors seem to indicate when the AC runs. That's consistent with my playing with it anyway. I'll let you know when I get to open it up if I find anything out.
Edit: also, notice the amber for the 2 defog options. The compressor will run for those 2 and I have used the defog+floor option to cool off my tootsies.
I recall in the fine print of the GM Service Manual, that the Selector Switch is a compound unit. It has multiple layers and has a combined vacuum valve/switch (for the duct vent doors) and electrical switch. (for the A/C command) I've always wanted to tear apart the switch and see how it looks but didn't want to risk having to get a new control panel in the event of failure...
So, I would expect that it would be VERY challenging to modify the actual switch to behave how it is desired here. The path of least resistance is probably to add a lighted push-button switch to manually command the A/C on/off (like many modern cars) and then also let the existing switch do the same. (So, you wouldn't be able to select defrost and not have the A/C on.) That switch would just manually jump the brown to green/white wires when you'd select it on.
Jim
