Wiring A/F gauge
Old Aug 20, 2009 | 09:53 PM
Havoc54's Avatar
Default Wiring A/F gauge
Trying to wire my air fuel ratio gauge up. It's just a narrowband, I need to know which wire to tap into to get a signal for it.
p.s. I know widebands are better..
Thanks for any help
Old Aug 21, 2009 | 06:23 AM
Havoc54's Avatar
bump....
Old Aug 21, 2009 | 04:34 PM
LS1Fury!'s Avatar
purple wire. But have fun having a pointless gauge.
A/F gauge should only be setup via wideband.
Old Aug 21, 2009 | 06:18 PM
Havoc54's Avatar
Yes i know its useless. I got it for free. That's why i stated in the first post i know widebands are better. Which purple wire is it? There are like 7 that are going into the pcm.
Old Aug 21, 2009 | 10:18 PM
LS1Fury!'s Avatar
Sorry I should have been more clear. You need to tap into the purple wire coming off an 02 sensor.
Old Aug 22, 2009 | 12:29 PM
Havoc54's Avatar
Is there a certain place in the engine bay with wire is running that i could tap into, and does it matter how close to the 02 you tap the wire in?
Old Aug 22, 2009 | 08:51 PM
LS1Fury!'s Avatar
You will have the least amount of resistance closest to the 02 sensor. However, the gauge will still be completely inaccurate unless WOT. I would just send a wire down there if you're persistent on using the narrowband.
Old Aug 22, 2009 | 09:12 PM
Grifter's Avatar
Why not sell the narrowband and put the money towards a wideband?
Old Aug 22, 2009 | 09:22 PM
ttranssam's Avatar
dunno in his case but mine....i just spent 5 gino in h/c/i, and n2o....and narrow band in conjuction to my nitrous controller works great due to the fact it also acts as a set point for a a/f lean cut out...so its not soooo pointless
Old Aug 22, 2009 | 09:24 PM
ttranssam's Avatar
but yes the idol sweep is annoying as hell....ive got a switch to turn it off when in traffic lol
Old Aug 22, 2009 | 10:33 PM
LS1Fury!'s Avatar
That's why I hate them setup narrowband. The fireworks display is sooo friggin annoying. Even at WOT it's not completely accurate.
