07 Yukon factory remote start
Old Aug 25, 2009 | 08:46 PM
SPDMETL's Avatar
Default 07 Yukon factory remote start
Is there a trick to making this work ? It will go about every fifth time. Some of those times the lights flash but nothing else happens. The lock/unlock feature works perfectly as does everything else.
Old Aug 25, 2009 | 09:01 PM
95TAJade's Avatar
Are you sure that you're pressing the R/S button all the way down? My g/f's car has factory remote start on her 06 Malibu Maxx. On occasion, I've had to press so hard on the key fob that I almost broke the damn thing. Cause if it still works every 5th try as you say...than it hasn't lost programming.
Old Aug 25, 2009 | 09:06 PM
SPDMETL's Avatar
I wondered about pushing harder...maybe it's the fob itself ??!!?!?!? We got this thing less than a week ago, so I don't know anything for sure
Old Aug 26, 2009 | 08:14 AM
SPDMETL's Avatar
bumpity...
Old Aug 26, 2009 | 10:08 AM
95TAJade's Avatar
If you got it from the dealership, I'd take it back and just have them double check it just to be sure. If you got it from an individual...you might try opening the key fob's casing and take a look at the circuit board to see if there's any cracked solder points or anything that doesn't "look right"
Old Aug 26, 2009 | 09:17 PM
SPDMETL's Avatar
Thanks; I will have to check the fobs. If something is fubar I'd much rather replace those than have somebody elbows-deep in the wiring harness !
Old Aug 29, 2009 | 01:08 PM
jam01's Avatar
the factory remote start will only work twice until you put the key in. it also wont start with the hood open, or at least that is the way it is designed.
