loose ground?
Old Aug 30, 2009 | 04:47 AM
Brian'sCharlotte(TA)'s Avatar
Default loose ground?
Ok, when i'm driving the car around casually everything is fine most of the time. When i'm driving aggresively oron a really bumpy road, the head unit and my windows will stop working. Completely losing power and will stay powerless for an undetermined amount of time. I have checked the fuses and the wires behind the head unit and nothing. One temporary solution i have found is that if I start the car with the window buttons pressed (up or down) after the car has been malfunctioning, the power immediatly comes back.
PLEASE HELP!
Old Aug 30, 2009 | 02:36 PM
WhiteBird00's Avatar
Ungrounded Moderator
It's your RAP circuit cutting out, probably because of bad solder joints in the BCM. Check out a solution in this thread.
Old Aug 30, 2009 | 10:31 PM
Hey Thanks!
