Wiring some stuff
Old Sep 13, 2009 | 04:11 PM
ExceSSive's Avatar
Default Wiring some stuff
This may be a newB question...I am trying to re-wire my Line lock and my QTP E-cutout. I need some help.
1. I have a 2 wire set-up for the line lock. Does it matter that the switch on my switch plate has 2 wires? Use the outer 2? One give away the hot source but no marking on the other side.
2. I have a QTP electric cutout it has multiple wires and the switch I have only has 6? Which ones do I use and how to I re-wire this thing?
Pics
Ashtray Switch plate...top right is cutout, top left is line lock.
Cutout switch...
Old Sep 13, 2009 | 05:00 PM
bmnicolosi's Avatar
The third pole on your switch should be for it to light up if it is a singlethrow switch, or if its a dual throw switch the middle is common and the two outers go with the switch in that position.
Old Sep 13, 2009 | 07:36 PM
ExceSSive's Avatar
So the middle one on the line lock goes to the light? It is a ground maybe and the red feeds both or a red/power and the ground feeds both?
Old Sep 13, 2009 | 07:53 PM
bmnicolosi's Avatar
if i can read it correct, it has A, B, and -. A and B go to 12v source and linelock input. Either can go to either. Then ground to -
Old Sep 13, 2009 | 07:55 PM
bmnicolosi's Avatar
on second look, if its 1, 2, 3. i would say 1 and 2 to what i called a and b, and 3 to ground
Old Sep 13, 2009 | 08:13 PM
ExceSSive's Avatar
Here is a diagram of the switch I just found.
A diagram of the QTP switch or a similar one.
http://quicktimeperformance.com/FAQ/...dualswitch.pdf
Could not get it in a pic...
Old Sep 13, 2009 | 08:15 PM
ExceSSive's Avatar
From the 2 pics, what do I do with the 2 extra wires/connections?
