Brake/turn signal problems! Please help!!!
Not sure which sockets you are talking about where, but if you have water inside, that's a bad thing that needs to be fixed. Cold water in the lenses can cause bulbs to shatter, or the socket corrosion. The running light lenses often get cracked by road debris, but the cracks are hard to see. Press on the front of the lens with your finger and if you see any cracks/separation, (or standing water) then you'll need to replace the lens.
I'm working on a way to do a similar thing to the rears.
