Steering Wheel Controls
Old Sep 30, 2009 | 11:28 PM
4THGENCAMAROFAN's Avatar
Default Steering Wheel Controls
What is needed to do to put a 98-02 Camaro steering wheel with radio controls in place of one that didn't have any??
Thanks
Old Oct 1, 2009 | 01:38 PM
funkymonkeys409's Avatar
a steering wheel with the controls and wiring, and radio from an 01-02, and some wire quick connectors
i bought a entire column. i had to change the air-bag wire connectors on each side (the section that runs up the column). they were a little diff from my 98.
then just splice into the dash light dimmer wire, power, and correct slot on radio harness (all 3 can be found on radio harness) https://ls1tech.com/forums/stereo-el...nsoon-faq.html
Old Oct 1, 2009 | 04:51 PM
Thanks man!! I didn't know there was a monsoon sticky...so what if I wanted to "throw in" an aftermarket radio...then what...do i just need to get the special adapter that the company sells for the radio??
Old Oct 1, 2009 | 08:35 PM
yea for the corresponding brand of radio.
Old Oct 1, 2009 | 09:29 PM
Sounds easy enough....thanks man
