Wiring line lock
Old Oct 6, 2009 | 11:00 AM
trey1010's Avatar
Default Wiring line lock
guys i will be installin my line lock
Today and have a quesion. How would I go about making the button that engages the line lock my preset button on my steerig wheel? Sorry for the possible stupid question but I don't know much about wiring . It is a sjm kit.
Old Oct 6, 2009 | 11:22 AM
RARON455's Avatar
I have the sjm kit on my car, I used a switch in my nitrous panel, that is in my ashtray. To be honest with you I am not sure that you can do what you are wanting. The controls in the steering wheel I believe go thru some kind of interface to work with the stereo.. Also I dont think that any of those buttons carry the correct +12, or a direct ground that you need to actuate the solenoid. Just my thoughts I could be wrong, but Iknow that all the wires are very small gauge wires, so even if you got it to work (which I dont believe can) , I dont belive it would carry the load for the solenoid, causing you to have to use a relay.
Old Oct 6, 2009 | 11:57 AM
trey1010's Avatar
thanks for the quick reply, okay well I am wanting it in a spot that I can reach while my right hand is on the shifter or while my left is on the steering wheel. I
Was thinking maybe right to the left of the volume **** on the plastic
Border thing around the stereo,
Although it may look out of place
Old Oct 6, 2009 | 08:37 PM
funkymonkeys409's Avatar
i know its not what your looking for but its just for another option you can do. im happy with it
https://ls1tech.com/forums/stereo-el...me-switch.html
Old Oct 8, 2009 | 12:04 PM
trey1010's Avatar
That for the replys, I have already wired it all up . I have master switch and light in the little cubby hold thing next to the cig lighter. And the activator button in the ashtray. I want to wire it to a switch instead of the button so I could just switch it on instead of holding the button the entire time. Is this okay to do or is there a reason not to do that?
Old Oct 8, 2009 | 08:33 PM
the only reason not to would be if you or someone else flipped the switch accidentally with the master switch left on as well. then when u hit the brakes for say traffic or at a stop light/sign the brakes would remain held.
