double din help
Old Oct 12, 2009 | 08:09 AM
rcoers's Avatar
Default double din help
Do I need to remove the tab on the back of the factory tray when I install a double din? Some background - I'm installing a Pioneer AVIC F700 BT head unit into a 2001 Camaro. Using 6LiterEater's bezel. I measured and it seems like it should fit in there without having to cut it off, but wanted to make sure.
Old Oct 12, 2009 | 11:45 AM
VIP1's Avatar
Copy & Paste Moderator
I had to remove that tab on the back of the tray when I install a Pioneer AVIC-D3 in my car. Its plastic and metal. I cut off the plastic part and bent back the metal part. You'll also need to trim the top of the opening to be able to fit the Double-Din in the opening.
Here is my install:
https://ls1tech.com/forums/stereo-el...installed.html
Old Oct 12, 2009 | 12:03 PM
rcoers's Avatar
What did you use to cut it?
Old Oct 12, 2009 | 02:29 PM
VIP1's Avatar
I cut the plastic tab with a cutting disc on a dremel and I trimmed the top of the opening with a sanding drum on a dremel. Wear goggles when you do this because a lot of debris will fly. You might want to wear a mask too. Also, its a good idea to have a helper hold a vacuum near where you are cutting to catch the debris to minimize cleanup afterward.
