speaker attaching hardware and Kee audio question
Old Oct 13, 2009 | 05:27 PM
N20zuki's Avatar
Default speaker attaching hardware and Kee audio question
So I bought the Kee Audio upgrade and recieved them last week and am going to throw them in. After looking at my factory speakers the sail panels are missing the sheetmetal clips and screws, the rear 4in speakers are held in with pop rivits? Havent even looked at the doors yet. Do you think the factory will have the attaching hardware in stock and does anyone have pics of there installed CDT's?
And are you able to use the CDT crossovers inline with the monsoon amp and I thought I read the monsoon system has a crossover before each speaker, so do those have to be removed or just wire the speakers inline and go?
Old Oct 13, 2009 | 05:39 PM
LS14EVR's Avatar
You might want to use the search function. All your questions will be answered.
I wrote one of them.
In short, you'll be using factory harnesses, doing away with the rivets, and coming up with some screws etc.
Old Oct 13, 2009 | 05:46 PM
N20zuki's Avatar
Got it, thanks..
Old Oct 13, 2009 | 05:55 PM
LS14EVR's Avatar
My rear pop rivets were already gone. I used some small bolts with nuts and washers. Sail panels were screws, same as fronts. If you are using the stock HU, and monsoon, then do not use the crossovers. Cust the connections off the stock speakers and make your own wired to the CDT's. Then all you have to do is plug them in and put in the screws.
https://ls1tech.com/forums/stereo-el...tall-pics.html
