Bcm
Old Oct 19, 2009 | 11:38 AM
white2001formula's Avatar
Default Bcm
I picked up a used BCM that supports keyless entry and replaced my non-keyless entry BCM about a month ago. Everything worked flawless for a while, and now I have a problem. The door lock is cycling multiple times. I drove to work today (5 minute drive) and I heard the solenoids activate probably 50 times in the Lock direction.
Now, I probably know my answer but I wanted to see if this problem could possibly be related to this thread. In this thread it basically talks about issues dealing with Radio / Power Windows randomly going off. Apparently some T-Connectors need to be resoldered. Since the BCM also controls door locks, I thought it might be related. All fingers point to the BCM malfunctioning in some way.
https://ls1tech.com/forums/general-lsx-automobile-discussion/883334-ls1-body-control-module-problems-fix-4.html
